1. Abra o menu de widgets
Deslize o dedo para a direita no ecrã.
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-67b24d2a-8f47-40eb-b029-592ba4bc06dc.png?width=212&height=458)
2. Adicione um widget
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-c943156b-e00e-478f-8e91-4f0a48cef9f1.png?width=212&height=458)
Prima Editar.
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-8b7a57f5-7a13-45b6-b5ad-754a63155f95.png?width=212&height=458)
Prima o ícone para adicionar.
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-bb06a3dd-d16f-450f-883a-2cca3d182497.png?width=212&height=458)
Prima o widget pretendido.
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-07a6d764-9223-4cb8-8159-d3a4adfe2070.png?width=212&height=458)
Se o widget pretendido não for mostrado na lista, prima o campo de procura e siga as indicações no ecrã para encontrar o widget pretendido.
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-0db6df04-0913-407e-823f-a6805a889e1f.png?width=212&height=458)
Prima Adicionar widget.
Prima OK.
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-6d647a9d-caa2-4634-befc-dcafc33a5706.png?width=212&height=458)
3. Adicione uma pilha inteligente
Prima Editar.
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-764a42de-55d1-46ca-aea9-941c2ecffec1.png?width=212&height=458)
Prima Pilha inteligente.
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-581c8e63-45e7-43aa-9fb3-898439242e97.png?width=212&height=458)
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-b06b65f0-ec35-4bba-801f-39d8e862e65a.png?width=212&height=458)
Prima OK.
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-35adab0c-c94f-44a7-a7ba-7e159a351f88.png?width=212&height=458)
4. Crie uma pilha de widgets
Prima OK.
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-5fa13a28-4aeb-47d7-9eaa-26dec348955c.png?width=212&height=458)
5. Ajuste a pilha de widgets
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-942dcc25-01e5-4e78-a211-800cc304603b.png?width=212&height=458)
Prima Editar pilha.
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-97b3575e-e911-499a-8803-72fe57f4c2d9.png?width=212&height=458)
Prima Rotação inteligente para ativar ou desativar a função.
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-7683ac4a-14c0-45b8-9c99-383dc6b5627c.png?width=212&height=458)
Prima o widget pretendido e arraste-o para o lugar pretendido.
Prima o ícone para apagar sobre o widget pretendido para o remover da pilha.
Prima OK.
6. Remova um widget
Prima Remover widget.
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-810a3a6e-f4ee-4ea3-8ebe-d57045cd4af9.png?width=212&height=458)
Prima Remover.
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-173a5247-db99-47f7-94b7-7baba0b2ce02.png?width=212&height=458)
7. Coloque um widget no ecrã inicial
Prima OK.
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-f1a9c0fd-fd34-4efd-8b85-b868ad3e4bf3.png?width=212&height=458)
8. Utilize widgets
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-7f51723c-04ce-49df-ae28-ee3d3c15f560.png?width=212&height=458)
9. Volte ao ecrã inicial
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-611b1fdb-1051-4731-99f1-04b99407a160.png?width=212&height=458)
