1. Abra o menu de widgets
Deslize o dedo para a direita no ecrã.
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-c440372e-6173-4a4d-8481-382dcfcc4101.png?width=210&height=456)
2. Adicione um widget
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-99b21d13-a331-4d4a-82b7-181cf53803d4.png?width=210&height=456)
Prima Editar.
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-54c0215c-5040-4854-9ff6-f788cac7240d.png?width=210&height=456)
Prima o ícone para adicionar.
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-fd9746be-269b-48c7-925d-b026e4dc91c6.png?width=210&height=456)
Prima o widget pretendido.
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-01b52292-9b76-4e77-8cca-998c2745b8b3.png?width=210&height=456)
Se o widget pretendido não for mostrado na lista, prima o campo de procura e siga as indicações no ecrã para encontrar o widget pretendido.
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-80393643-3e7c-4ebc-b149-1c33d345a8cf.png?width=210&height=456)
Prima Adicionar widget.
Prima OK.
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-7d764d23-c2eb-45a3-9828-a7bc62b31ea3.png?width=210&height=456)
3. Adicione uma pilha inteligente
Prima Editar.
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-a5e93b87-00bc-43d6-b777-700662ed100d.png?width=210&height=456)
Prima Pilha inteligente.
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-59afb678-a591-4797-9093-3d00a7f1971f.png?width=210&height=456)
Prima OK.
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-7f36a735-541a-4fb3-95ab-055d7a279a66.png?width=210&height=456)
4. Crie uma pilha de widgets
Prima OK.
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-656c9e40-79ca-457b-8fd9-836d72320eb9.png?width=210&height=456)
5. Ajuste a pilha de widgets
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-0b63bf3d-c285-4151-9eb3-55c9da4fcfb4.png?width=210&height=456)
Prima Editar pilha.
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-c17b83b8-36a6-4a94-abff-94fca784da8f.png?width=210&height=456)
Prima o indicador junto a "Rotação inteligente" para ativar ou desativar a função.
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-cc1c4c7a-36de-4490-a2f0-3ea04e84542a.png?width=210&height=456)
Prima o ícone para mover junto do widget pretendido e arraste-o para a posição pretendida.
Deslize o dedo para a esquerda sobre o widget pretendido para removê-lo da pilha.
Prima o ícone para terminar.
6. Remova um widget
Prima Remover widget.
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-f367e775-495e-4357-b368-416bffb096c7.png?width=210&height=456)
Prima Remover.
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-de61ad31-c7fa-43f6-94ad-1b09874a16a6.png?width=210&height=456)
7. Coloque um widget no ecrã inicial
Prima OK.
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-6acbc02d-7532-4cef-9965-fc834107c7ae.png?width=210&height=456)
8. Utilize widgets
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-b15797ed-dfe0-4bbe-b6f2-d73bce069197.png?width=210&height=456)
9. Volte ao ecrã inicial
![](http://wmstatic.global.ssl.fastly.net/ml/7031023-f-02d408d4-36dc-4911-9215-ae8d9750b6df.png?width=210&height=456)
